Fuse #8
Old 05-08-2008 | 06:06 PM
bigdog9586's Avatar
Fuse #8
I have to pull fuse 8 in order to tow behind my motorhome. This is the Ignition Switch, PASS-Key® III+ fuse. Just what does this fuse do and what would happen if I just plain left it out and drove the car? I'm assuming this disables the locking steering column but may be wrong. If that is all it did I would leave it out permenitly.
Old 05-08-2008 | 06:48 PM
TomsHHR's Avatar
At least one member placed a switch in the wire to that fuse..
Saves time..
Old 05-08-2008 | 06:51 PM
Saves time..
bigdog is looking for a pro kind of set up.
https://www.chevyhhr.net/forums/general-hhr-4/pulling-fuse-8-tow-tow-hhr-14944/
Old 05-08-2008 | 07:30 PM
an08HHR's Avatar
The manual says Fuse 8 is ignition switch, pass key 111+
Old 05-08-2008 | 07:41 PM
bigdog9586's Avatar
But what would happen if I didn't replace it?
Old 05-08-2008 | 08:28 PM
an08HHR's Avatar
My guess it that it won't start. Don't know about the pass key part, may just disable the feature. Maybe Chevy Mgr can shed some light if he reads this.
Old 05-22-2008 | 03:34 PM
bigdog9586's Avatar
UPDATE:
I found out what happens if not replaced. The car can start and as far as I know run but it won't let the key turn past off. So it won't go into lock so I can remove the key. Also cuts power to some other stuff like dome lights I think.
Old 05-22-2008 | 10:13 PM
Cyclic Hardover's Avatar
May want to make sure you leave the windows down
Old 05-23-2008 | 01:45 PM
bigdog9586's Avatar
Why leave the windows down?
Old 06-17-2022 | 11:57 PM
McB_HHR's Avatar
Necro thread being brought back! It was relevant to a thing I went through recently. Anyway, for the archives, this will likely also disable remote start. Failure may look like interlock issue
