Getting engine code P0010 and service traction
I am getting P0010 engine code and at the same time it says service traction. I have order the intake and exhaust Variable Valve Timing (VVT) Solenoid / Actuators. will be changing the oil first even thought it shows 63% on oil setting. I know the actuators going bad is common but what is with the Service Traction on the dash..Do they go together? Thanks for your input. 2007 HHR with a 2.4l motor
When the P0010 sets the traction turns off, thus the warning.
They left a few words out of the name of the test. You need to replace the VVT valves. If you can only afford 1 get intake.
This is for the CIURCUIT so ether the coils inside the solenoid are fried or a wire is loose. No need to worry about the oil.
vrg813
08-25-2018 05:27 PM
Cascious King
05-08-2014 09:50 PM
