Getting Flashed at by Other Cars
I was having that problem, took mine to my best friend's dealership and put it on the light machine, I was high my millimeters, set them and problem went away and lights are still great. I also have 55w bulbs in the fogs and have them set to just touch the back edge of the low beams.
Cargo or extra passengers lower the back end of your HHR. I did the 1 turn on the lowering to remedy the issue, did it on my Silverado for trailer towing.
I thought I had put some pics and a how to back in 2005 or 2006.
But here is another that explains. The up-down adjustment is next to your hood strut on the fender well.
And on my bike the headlight is adjustable while you are riding and I keep that adjusted as well depending on load conditions.
Seems simple to me - if people are frequently flashing you at night, it means your headlights are aimed a bit too high. The adjustment on the HHR (at least on the 2006) is almost too easy via the adjusters (all that is needed is a 6mm Hex wrench - not a torx! and adjust via the alignment socket which is located under the hood through the fenderwall at the rear of each headlight).
flashed headlights
In my opinion it could be 1 of 2 things.
1) being a way of saying at 50mph hello I got one too....at least a quick flash in the daylite (not nice@nite!)
2) away of saying you need your headlights adjusted...(maybe you have a lawnmower or something heavy on the cargo area or a bike rack and bike causing the lites to point up.)
My guess is the first guess....
Last edited by hermit375; 11-14-2010 at 12:03 PM. Reason: further explantion daylite vs. night time flash
