GM update for today
Old 09-17-2007, 10:28 AM
hvrod's Avatar
Found some info Updates on HHR
Updates for HHR
Week of 8/20/2007
Effective 8/20/2007, the following changes will be made to the Vehicle Order Guide:
• Interior section-Added (ATY) Rear seat delete. It is "A1" on 1AT46 1LS with a footnote that reads "Requires a Fleet or
Government order type, (UE0) OnStar delete, (19B) Ebony Cloth interior trim and either (41U) Black exterior color or (50U)
Summit White exterior color. Not available with (PCW) Enhanced Safety Package."
• Exterior section-Added (AA5) Rear quarter panel. It is "A1" on 1AT46 1LS, 1AS46 1LT and 1AS46 2LT with a footnote that
reads "Not available with (32*) Cashmere interior trim."
Week of 7/9/2007
Effective 7/9/2007, the following changes will be made to the Vehicle Order Guide:
• Mechanical section-(L61) Engine, ECOTEC 2.2L DOHC 16-valve 4-cylinder SFI, added an extended description that reads
"(149 hp [111.1 kW] @ 5600 rpm, 152 lb-ft of torque [205.2 N-m] @ 4200 rpm)".
• Mechanical section-(LE5) Engine, ECOTEC 2.4L DOHC 4-cylinder SFI, added an extended description that reads "(172
hp [128.3 kW] @ 5800 rpm, 167 lb-ft of torque [225.5 N-m] @ 4500 rpm)".
Week of 5/28/2007
Effective 5/28/2007, the following changes will be made to the Vehicle Order Guide:
• Interior section-(UE0) OnStar, delete, changed symbol to "A2" on LT 1AS46 2LT and Panel LT 1AS26 2LT with a footnote
2 that reads "Requires a Fleet or Government order type. Not available with (U2K) XM Satellite Radio."
• Exterior section-(NZ6) Wheels, 16" (40.6 cm) custom spoke, changed description to now read "Wheels, 16" (40.6 cm)
fascia spoke, painted Sterling Silver".
Week of 5/21/2007
Effective 5/21/2007, the following changes will be made to the Vehicle Order Guide:
• Interior section-(U2K) XM Satellite Radio, updated footnote 1 to now read "Included and only available with (PDU)
Enhanced Sound Package. Available in the 48 contiguous United States. Required $12.95 monthly subscription sold
separately after 3 trial months. All fees and programming subject to change. Subscription subject to customer agreement.
For more information, visit gm.xmradio.com." Also, updated footnote 2 to now read "Available in the 48 contiguous United
States. Required $12.95 monthly subscription sold separately after 3 trial months. All fees and programming subject to
change. Subscription subject to customer agreement. For more information, visit gm.xmradio.com."
Week of 5/14/2007
Effective 5/14/2007, the following changes will be made to the Vehicle Order Guide:
• Interior section-(UE0) OnStar, delete, updated footnote to now read "Requires a Fleet or Government order type. Not
available with the combination of [(UQ3) 7-speaker audio system and (L61) 2.2L engine] or [(UW5) 6-speaker audio
system, (JM4) 4-wheel antilock front disc/rear drum brakes and (L61) 2.2L engine] or [(UQ3) 7-speaker audio system,
(U2K) XM Satellite Radio and (LE5) 2.4 L engine]."
hvrod is offline
Old 09-18-2007, 09:14 AM
Dan's HHR's Avatar
thanks for sharing
Dan's HHR is offline
Old 09-18-2007, 10:13 AM
betterof2evils4's Avatar
Why would they not make available the Rear Quarter Panel option to the Cashmere interior HHRs? That just doesn't make sense (to me) how one of those options affects the other..
betterof2evils4 is offline
Old 09-18-2007, 10:33 AM
JoeR's Avatar
Probably 'cause the Panel is only offered with grey or ebony interiors. The quarter panel rear window delete would have the same interior pieces as the Panel. Does that make sense?
JoeR is offline
Old 09-18-2007, 10:41 AM
Oh.. I was unaware the panel only had those two color interiors...
Old 11-05-2007, 11:43 AM
hvrod's Avatar
GM update for today
Updates for HHR
Week of 11/5/2007
Effective 11/5/2007, the following changes will be made to the Vehicle Order Guide:
• Exterior section-(5V4) Limited Personalization Option, HHR Appearance Package, added a footnote 1 that reads
"Requires exterior color (37U) Imperial Blue Metallic, (41U) Black or (67U) Silverstone Metallic." and applies to 1AT46
1LS, 1AS46 1LT and 2LT, 1AT26 1LS and 1AS26 1LT and 2LT.
hvrod is offline
Old 11-05-2007, 12:14 PM
Frozenspokes's Avatar
Originally Posted by hvrod
Updates for HHR
Week of 11/5/2007
In English?
Frozenspokes is offline
Old 11-05-2007, 12:19 PM
Originally Posted by Frozenspokes
In English?
I think HVROD is expecting people to follow all his threads of the updates, in which the codes and meanings are contained throughout. If you take a look back at his previous update threads, you should be able to find what you're looking for.
Old 11-05-2007, 12:53 PM
hvrod's Avatar
yep
hvrod is offline
Old 11-05-2007, 02:45 PM
Markiemark's Avatar
In English?
+1, was thinking the exact same thing?!?!?!?!
and I have seen, past posts!!!!
Yep --- What????
Later
Markiemark is offline
Quick Reply: GM update for today
