Is this a good deal
Then go to your local GM dealership Parts Department, give them your VIN and request an RPO decal for your glovebox door. They may redirect you to Service, one of them should GIVE you a printout. I am pretty sure the decal is a required piece of equipment, I don't know why an honest person would remove it.
They can probably get you the other docs also.
I hadn't bought a car in SEVERAL years so this is new to me.
What is an RPO decal and what does it tell...??
Oh and how come it's a 'required' piece of equipment....
Obviously I need educated about this item
I would say it is a 1LT just from looking at the picture and what engine it has.
SF
The RPO sticker in the glovebox (if there is a sticker),will look like the picture below. You can take those option numbers and get the descriptions from the this link :
https://www.chevyhhr.net/forums/gene...options-12674/
Just to be sure.
We are talking about the actual glove box in front of the passenger seat.
Not the pop-up box in the center top of the dash board.
A little fwiw. While you're rummaging around in the real glove box, you may want to check the condition of your cabin air filter. The filter is located behind the glove box and should be changed out periodically like the engine air filter.
yeah right box.... just nothing there.
Have no clue why it would of been removed....
Thanks for the tip about the filter.
I just got this car a few days ago and am learning all sorts of new stuff about it
