Good ground spot under dash?
I'm getting ready to install a fuse tap to power my new dashcam. I'm tapping into the passenger side fuse panel but just looking in the area, I don't see a good screw or bolt to use for the ground wire. Everything looks like plastic around the fuse panel. Has anyone done similar and know of a good metal connection in that area or under the dash on passenger side? Thanks gentlemen.
Here it is: https://www.chevyhhr.net/forums/gene...-rental-62024/
Right under the cover for that fuse panel is some metel. I just drilled for a small sheet metal screw. There's pic of it here somewhere. The thread was about the remote started hack for 2008 rentals.
