got the plastic wheel and want radio controls??...
part number for black leather steering wheel
The part number for the HHR black leather steering wheel is
#15907684
Price is $118.39 plus 26.05 S&H (total $144)
This includes the harness and radio buttons and silver bezel covers.
The buttons are the "tall ones" as in the 2007.
Good luck!
-Brrrrroom Brrrroom....
Anyone want to buy my old resin steering wheel? (Black with silver bezels)
#15907684
Good luck!
Well, The Black Leather wrapped Wheel arrived, with silver Bezels.
Installation was a snap. A recap for you for you:
-Detached Battery (Neg comes off first and goes on last!!)
-Used two long hex keys inserted into the small holes on the sides of the steering wheel, this releases a spring and the horn and airbag pops right out. (play with these on your replacement wheel first, its a pretty clever design.
-Removed two yellow hold tabs (plastic) that keep two electrical connectors attached to back of the horn/airbag. (Thats why you unhook the battery, you do not want to set the airbag off -potentially VERY dangerous if powered-) On my 2007 one plug was pink/grey and the other white/grey. Impossible to reverse. Nice design.
-Then used my socket to unbolt the steering wheel nut.
-Then wiggled the old wheel off. It took some wiggling.
-Detached the old socketed (cruise control) wiring from the old Wheel.
-its now off.
For reassembly everything was done in reverse. The horn/airbag attached with a good push into its spring clamps.
There were no settings to change on the radio etc. (Mine is a 2007 LT)
The new radio buttons worked perfectly upon re-attaching the battery (Positive first, then negative).
The only thing that took a long time was realizing that the horn/airbag MUST be detached at the back of the horn/airbag through the plastic plug connectors. These wires do not detach with a socketed plug at the same place the cruise control/radio harness attach.
Be sure you properly torque down the steering wheel nut, a drop of locktite is a good idea too. You do not, of course, want this coming off in your hands in 12,000 miles....
-its now off.
I also just did this swap! As stated above this is an easy and great mod!
The only thing that I did differently was remove fuse number 13 to disable the Airbag.
Now I am wondering if my standard Ebony steering wheel that I took off would be worth anything to anyone?
Thanks to the members that posted this originally.
Wheel installed very easy. I didn't unplug battery, but did pull fuse right by battery, and #13 to disable airbag. Had a tough time taking off wheel, but a few sprays of WD40, and it wiggled right off.
One thing, make sure that the piece under the wheel does not unwind. mine did, and i didn't set it correctly, the wheel didn't make a full left turn because of it I had to take the steering wheel off and turn that piece one rotation to the right.. works like a charm now!
Was first done on an 06 model..........
https://www.chevyhhr.net/forums/how-tutorial-library-21/adding-radio-buttons-steering-wheel-1912/
