Ground for trailer wiring
I am adding the wiring for a small utility trailer. I read the towing specs for the HHR and will be well within the limits.
My question is the instructions say to drill a hole for the ground wire to the frame. No real frame. It also says not through body or exterior. Is the floor back near the tailgate considered frame for a ground.
Just sitting here thinking maybe it will be obvious when I get out there.😀
Thanks
Thanks
I grounded my trailer harness inside the drivers side access hole , like this member did
https://www.chevyhhr.net/forums/how-...-wiring-32903/
