Had the rear shocks changed about 5 months ago.
Yesterday I was driving and all of a sudden I had a loud dragging in the rear of the car. Pulled over on a side road and looked under the car. The right rear shock was off and dragging on tire rim. Took it a shop close to where I was and they said it needs new rear shocks and they have to order the right rear shock bolt from dealer tomorrow because its gone. Should I call the shop that did the rear shocks 5 months ago? Also how hard will it be to get that bottom bolt?
If you don't mind a delay, call the shop that installed, see if they'll stand behind their work. You'll want to tell the new shop to hold off until you get an answer.
Part Number 11518185
Seems to be readily available.
