Harbor Freight Torque Wrench
Just bought the Harbor Freight 1/2" Drive Clicker-Style. After I brought it home, I read online that they tend to be inaccurate. It was only $15, but all I'm really doing is torquing the calipers after changing brakes, and the lugs once I change back from the Studded snows. Are these people just all about name-brands, or is the Harbor Freight really a bad choice?
Thanks,
Andy
Thanks,
Andy
If you can find one, buy a used Snap-On and since they're guarenteed for life they'll fix and calibrate it for you. They might charge to calibrate it, but if anything is broken they'll fix it for free. Mac and Matco should be the same way.
Andy.....
Several years back, my former employer, purchased 3 each of 5-6 torque wrenches, of the "clicker" type, by various manufacturers. Purchases were from retail outlets (no special order). The purpose was to test and determine which produced the most accurate results "out of the box". Then after calibration which would remain accurate, or have the LEAST variance from continual every day use over a period of 6 months.....ultimately providing the best utility.
Harbor freight failed horribly and continued to fail horribly during the 6 month trial (out of the box...was 6-11 ft#'s @ 100 ft#).
Best was Snap-op...second best was Craftsman (at about half the cost)...Matco was next.
Remember, this was several years ago. All manufacturers produce several versions/models. I do not have the model numbers....which probably changed by now.
Andy.....
I buy a lot from Harbor Frieght
I have bought a lot from them including a clicker type torque wrench. Most of their tools are not very good but I buy them for my shop because my crew loses or breaks tools. A screwdriver is NOT a prybar!
On the Harbor Freight clicker style torque wrench save your money and buy a better one. Mine would not hold its setting and literally fell apart. I do not know about the accuracy of it but I doubt that was very good.
That's PROBABLY the one I received as a retirement gift, several years ago. I like it and it was just recertified for accuracy (along with my Craftsman "clicker" and my digital air gauges).
The biggest no-no with the clicker type torque wrenches is that people tend to forget to back off the spring tension after they finish using it...quickest way to inaccuracy. And no, I wouldn't trust a Harbor Freight torque wrench! Buy a name brand like Snap-on or Mac with a lifetime warranty...it'll last a lifetime if properly cared for!
