Hard shift
Old 02-20-2022, 10:23 AM
Gearhead1's Avatar
Hard shift
Ok…I have limited experiance with automatic trans….what would make one shift weird and hard in all gears?
Gearhead1 is offline
Old 02-20-2022, 10:31 AM
Any CheckEngineLight?
donbrew is offline
Old 02-20-2022, 10:33 AM
Gearhead1's Avatar
no…but door lock/ unlock started acting up at same time….wondering if related electrical issue…maybe bad ground?
Old 02-20-2022, 10:36 AM
What voltage is at the battery? The symptoms you described indicate a dead cell in the battery or just a dead battery!
Oldblue is offline
Gearhead1's Avatar
ok…will check that
Old 02-20-2022, 10:41 AM
Gearhead1's Avatar
Honestly,….this is friends car…06, 2.2…all this started about 2 days ago.
Old 02-20-2022, 10:51 AM
Gearhead1's Avatar
Says car has P1818 code…trans pressure…could be eletrical
Old 02-20-2022, 11:09 AM
https://www.engine-codes.com/p1818.html
I haven’t seen this code for HHR’s, but the Cobalt site has.
It’s either a pressure solenoid for the torque converter, squirrel chewing the wires or a Ryobi rechargeable battery!
Oldblue is offline
Old 02-20-2022, 11:22 AM
Gearhead1's Avatar
Thanks….friend is towing the car now on way to Pennsylvania…,relayed all the info from you guys, especially checking battery and fluid level
Old 02-20-2022, 12:53 PM
Lonwane's Avatar
Rechargeable battery?
Good one.
Aren't most batteries rechargeable?
I for one am glad for that or they would have to continually replace the one in my head.
Lonwane is offline
Quick Reply: Hard shift
