Hard Water Crud on Rear Door Windows
Old 08-25-2008 | 01:12 PM
playgames1970's Avatar
Has anyone else noticed hard water buildup along the bottoms of the door windows, along the black moulding? I'm noticing that in particular my rear door windows are developing a little bit of white hard water crust just underneath the black rubber, along the rear part of the window opening. I can't seem to wipe it away, and there's no way I'm putting anything too harsh on the paint to try to dissolve it. I dry the car as best I can when I wash it, and use that Mr. Clean (supposed) reverse osmosis carwash system, but I have noticed that those mouldings hold a good amount of water underneath them, to where you can come back to the car hours after washing it and there's still water oozing around underneath them.
I was just wondering if anyone else has noticed this on their car, and if anyone has a suggestion of what might help get it off/out. Thanks!
Old 08-25-2008 | 01:25 PM
la.redo's Avatar
Do you have a air compressor ? I take and turn down the air pressure on mine and air dry after I wipe it down , then wipe it down one last time so there is no hard water spots ;]
Old 08-25-2008 | 01:38 PM
GRUMPEE's Avatar
Compressed air is a good idea, even so you'll still need to do a short drive after your wipe down to ensure all the water is forced out. You'll still see some water stains, but that can be wiped off using some quick detailer
Old 08-25-2008 | 10:48 PM
Daverb's Avatar
I have used Barkeepers Friend to clean hard water spots from my windows. Sometimes it may take a couple of applications, just follow the directions on the can. I bought mine at Wal Mart in the cleaning section with the cleansers
http://www.barkeepersfriend.com/
Another product I just tried this weekend to get the wax off the rubber of the running Boards and rear bumber protector is LA's Totally Awesome multipurpose cleaner. Again follow the dilution recommendations. I used it full strength and a denture brush to remove the wax, and it worked well. Bought it at dollar general/
http://www.lastotallyawesome.com/faq.html
Old 08-26-2008 | 11:12 AM
Thanks for the tips...appreciated!
Old 08-26-2008 | 12:16 PM
GCarp's Avatar
Try a leaf blower?
hhrumadbruh
Mods - Interior
18
01-30-2016 10:10 AM
2007HHRLT
12-11-2013 05:29 PM
emstess
04-19-2010 04:25 PM
Goose
06-24-2008 11:46 PM
Krusty
7
12-26-2007 02:03 PM
