hatch door won't lock
Old 01-11-2020 | 12:05 PM
ldellington's Avatar
Question hatch door won't lock
Just bought a 2010 HHR panel van. The rear hatch door won't lock?? Any suggestions?
Old 01-11-2020 | 12:35 PM
Welcome to the site, lubricate the mechanism, check for loose or broken wires.
Old 01-11-2020 | 12:41 PM
Make sure there is NO fuse in position #11 under hood fuse box.
Old 01-11-2020 | 12:42 PM
Hi ldellington, to the forums!
In the underhood fuse block, check that fuse #10 is good, and that there is no fuse in #11.
Old 01-12-2020 | 02:37 AM
Cat Man HHR's Avatar
What circuit is completed IF a fuse is in #11 ? Thanks.
Old 01-12-2020 | 06:11 AM
From the TSB and recall list:
#PIC5055: Rear Hatch Will NOT Lock - keywords door fuse gate latch lift liftgate lock pad release RKE touch UBEC unlock - (Dec 11, 2008)
Subject: Rear Hatch Will NOT Lock
Models: 2006-2009 Chevrolet HHR
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
The customer will notice that at anytime by using the touch pad on the rear lift gate the lift gate will open WITHOUT unlocking the vehicle.
Recommendation/Instructions:
If this condition exists, check for a fuse in position #11 in the Underhood Buss Electrical Center. If there is a fuse in that position, remove it, as it is not supposed to be there.
Note: A fuse in that position will cause the release relay (coil side) to stay powered up at all times and will only need a ground (touch pad) to activate the relay.
If no fuse is present then check for voltage on circuit #1221 (WH/BK) and proceed with diagnostics.
Old 01-12-2020 | 10:03 AM
Thanks for that info.
Just a thought. Could using #11 be of a benefit at sometime ?
Old 01-12-2020 | 05:57 PM
I can’t think of an advantage to a fuse in #11
Old 01-12-2020 | 08:26 PM
It took me an hour but I figured out why it is there. I always assumed the Cobalt shared the fuse box, but no.
On a Pontiac Solstice which uses the same UBEC fuse # 11 is a totally useless thing tha powers the coil side of the trunk relay.
HHR
HHR liftgate release circuit
Solstice
Solstice trunk release circuit
Here are the complete schematics in pdf Attachment 47663Attachment 47664
myusedhhr
09-20-2024 09:01 AM
sky
03-22-2018 11:44 PM
tsmitty
11-29-2017 07:15 PM
jayweston
07-12-2014 04:01 PM
Blue Beast (aka Boydie)
07-16-2013 05:55 PM
