Have the dreaded P0121 code.
Old 11-15-2019 | 05:03 PM
Jim's 2009's Avatar
I did read a lot of threads on the subject but I have the code and my HHR is running fine. Any idea what I should be looking for, 2008 LT with 198,000 miles
Old 11-15-2019 | 05:55 PM
The throttle body connections can be simply dirty and corrosion has set in. Check the connection for loose or bent pins. Clean and dielectric grease the connections.
Do not move the butterfly plate manually, clean it with CRC throttle body cleaner.
https://www.obd-codes.com/p0121
Old 11-15-2019 | 06:21 PM
Jim's 2009's Avatar
I have been looking, found nothing yet. Have to continue looking. I find it odd that it's running so good with no drop in mpg after reading other posts on the subject. Thanks
Old 11-15-2019 | 06:26 PM
It might just be the harness was pulled at during an oil filter change. Just enough to trigger the OBD II code.
Old 11-15-2019 | 06:27 PM
Have you tried clearing the code to see if it returns ? Since you don't see anything obviously wrong and you say it's running fine, maybe it was just a false, fluke reading.
Old 11-15-2019 | 06:29 PM
Great point FMG, perhaps a battery lobotomy will clear this up. It will clear the codes. If it comes back , then you can go from there.
Old 11-15-2019 | 08:56 PM
WoodysMobile's Avatar
Clear codes
Agree with that and see what happens. (or doesn't )
It could be that simple. Or it will be diagnosed the last place you look, possibly...
Old 11-16-2019 | 01:54 PM
Jim's 2009's Avatar
I have cleared the code a number of times and it comes back. Something odd today, started out this morning no check engine light, stopped at the drug store came out started the car engine light on, went to Walmart came out no light. Didn't come on after that.
Old 11-16-2019 | 03:36 PM
That indicates to me a loose wire either in the harness connection or a ground wire.
Old 01-04-2020 | 10:28 PM
Jim's 2009's Avatar
Just a update on what's going on with my check engine light. After disconnecting my battery on number of times the light would go out for maybe three or four days. I then unhook the battery and unplugged every electrical connection under the hood that I could access. I cleaned all connections use Dielectric grease plugged everything back in reconnected the battery and now the check engine light will stay off for about a month at a time. Again I will unhook the battery the light goes out I can get a another month with no check engine light. I'm not sure what to try next.
