header install caused leak?
So I was installing header onto the 07 2.4... everything fit nicely, so I started to tighten bolts up. Walked away to change tools and noticed in now leaking liquid... lots of it, from the pipe under where the header/ manifold is..
What is that pipe? Any ideas on why it works have started leaking while not working on it?
Somebody else had the same problem last week. I think he ended up trying to rotate the transfer pipe a little. Evidently the headers are not designed for HHR, if you can find out exactly what car the template came from you could try getting a tube from one of them. In other words, contact the vendor.
I would consider using a BFH to deform the tube, if I thought a header would make a real difference.
The only way is to remove the t-stat housing then pull it out O-rings on each end, I believe there is a slot & tab alignment arrangement on one end maybe both ends; that would need "adjusting.
If you think you may need a water pump anytime soon you might consider doing at this time, since that is half the job.
If it was advertised to fit, I would contact the vendor and slowly escalate my demands.
No indication I need a water pump so ill stay away from that part... The tstat housing busted when I rotated the pipe.. So I yanked the one from the wrecked car, new O Rings and put it all back together..
Before tighting it down I turned the pipe so the Headers would fit. However, the O Ring on the pipe, Tstat side (driver side) wont stay straight and sealed when I turn the pipe. The water pipe lays against the engine like I found in this pic. But needs turned, so the bend is down.
However Like I said, when I turn the bend down, it wont seal at the O Ring.
