headlight problem?
headlight problem?
I was wondering if anybody was having problems with their headlights. I have an 06 and own it sense day one. I've had to replace my headlights 3 times already. The drivers high beam has burnt out 3 times in 3 years. Seems a little fishy to me. anybody else having this problem?
Double check your headlight ground wire. Maybe it's loose or not very well grounded. It is located under the hood on the drivers side inner fender. It's a bolt coming through with one wire on it. I had a light problem and improved my ground here to fix it.
