Heads up display (or whatever it is called) & OnStar*
Old 07-18-2008, 08:53 PM
Brwbier's Avatar
Just remember it's best not to run low on fuel. It's what lubricates your fuel pump. Every time you run down past the low fuel light it shortens the life of your fuel pump.
Brwbier
Brwbier is offline
Old 07-18-2008, 09:37 PM
1stTimerHHR's Avatar
Brwbier
HUH?
1stTimerHHR is offline
Old 07-18-2008, 09:49 PM
crazybob's Avatar
Originally Posted by Kennys2009HHR
On*Star uses Satellite not cell phone towers
It uses both. Cell phone for communication with OnStar and GPS for telemetry. The GPS satellites are used to locate the car, but without cell service you cannot contact nor talk to OnStar. The range is typically better than a standard cell phone nowadays.
Here's a LOT more info on OnStar:
http://auto.howstuffworks.com/onstar.htm
crazybob is offline
Old 07-19-2008, 01:57 PM
08blackHHRSS's Avatar
Brwbier
HUH?
The fuel pump has a electric motor, sits low if not on the bottom of the tank. Low fuel level in tank= fuel pump motor runs "dry"(not sitting in fuel),wearing out the motor prematurely.
Never a good idea to run each tank down to get last drops outa it.
08blackHHRSS is offline
Old 07-19-2008, 05:24 PM
mixman's Avatar
and what are you to do if you where ever in a area with no cell phone towers or you phone battery died?
Charge the phone with my ciglight adapter and walk until I get signal.
mixman is offline
Old 07-19-2008, 06:44 PM
Kennys2009HHR's Avatar
Kennys2009HHR is offline
mitzkity
South Pacific
18
03-24-2010 08:28 AM
HHRDK
2.2L Performance Tech
05-30-2008 10:12 PM
dixiesHHR
South Mountain
10
07-21-2007 04:27 PM
Krejaton
04-07-2006 05:43 AM
lou
10-31-2005 09:30 AM
Quick Reply: Heads up display (or whatever it is called) & OnStar*
