Heat shield broken?
Old 09-12-2020 | 09:43 AM
SullyinCT's Avatar
Heat shield broken?
Something is broken under my car. A friend says it looks like a heat shield. Driving wise it’s fine. But every time I go over a speed bump or any kind of raised road surface something scrapes.
Old 09-12-2020 | 10:22 AM
Since there is no real question, then I say Fix It.
Old 09-12-2020 | 10:40 AM
SullyinCT's Avatar
sorry...do you think it’s just the heat shield?
Old 09-12-2020 | 11:07 AM
It looks like a heat shield over the exhaust A couple of self tapping screws , not to long , 1/2 to 3/4 inch will do.
Old 09-12-2020 | 11:09 AM
I can't tell what part of 'under the car' that is, the camera is too close. Jack that part of the car up as high as you can, and take a better picture, with the phone touching the ground.
That being said, it does seem like a heat shield, but which one? If you're planning to DIY, then this thread can continue. If you're not mechanical, then take it to a shop. They'll order the correct parts and repair it.
Lonwane's Avatar
Sully,
From ypur picture that is what I see.
Crawl underneath and look.
Old 09-12-2020 | 11:58 PM
If only there was a place you could drive to have your car lifted up for inspection and repair. I am assuming that you would not know which end of a screwdriver to use as a hammer.
Whatever it is it has to be removed or fixed before it falls completely off and hits some innocent bystander. Kind of irresponsible driving around with parts falling off. "Just a heatshield" can kill a person at 65 MPH.
2003_2LT
Maintenance and Upkeep
04-11-2013 11:28 PM
peevlos
06-13-2010 01:50 AM
c2vette
04-26-2008 06:32 PM
jbbadboy
09-21-2007 11:19 PM
dbarberaz
05-04-2006 10:44 PM
