Heated seat issues.
Old 01-21-2020 | 05:58 PM
SwaintaN's Avatar
Heated seat issues.
So in my 07, the driver side seat, doesnt heat up. The heated seat button, when you press it, it flashes.. Passenger side works just fine.
Where do I start on tracking down the issue? Thanks!
Old 01-21-2020 | 06:11 PM
The LS model didn’t have the heated seats option, are they a factory set taken from a LT , are all the parts factory?
https://www.google.ca/search?q=2007+...&bih=626&dpr=2
it could be a faulty switch or temperature sensor
Old 01-21-2020 | 06:59 PM
SwaintaN's Avatar
That's what I have is an lt, they are stock heated leather seats.
Is there a way to test those?
Old 01-21-2020 | 11:29 PM
The same way you check any electric heating element; continuity.
The connector is under the seat.
Old 01-22-2020 | 02:53 AM
geg's Avatar
geg
thermocouple inside.
it is a relatively fragile thread.
Of course, it is protected from kinks - but it will only withstand your ass (wide spot of contact). But if you often step your one knee on the seat or your child likes to jump on it - the thermocouple can be broken.
Just peel off the leather cover and evaluate the damage to the touch and visually.
Find a broken place - replace the thermocouple, it's not expensive. If you don’t find a broken place - test the power supply.
Old 01-22-2020 | 07:27 AM
SwaintaN's Avatar
The person who had it before us was a bigger person, along with I used to be a bigger person. Add in they didnt take care of the car.. I'll order a seat set, hog rings and hog pliers, swap out the thermal.
Old 01-22-2020 | 09:01 AM
And inspect for loose connections under the seat
Old 01-22-2020 | 09:35 AM
SwaintaN's Avatar
I cant seem to find factory replacement thermals, under 2xx.xx each. Wonder if I could adapt universal ones to the factory wiring.
Old 01-22-2020 | 10:44 AM
Someone just posted universal heated seats recently.
a link in here post #20
https://www.chevyhhr.net/forums/mods...s-60921/page3/
Old 01-22-2020 | 11:56 AM
I would 100% rule out wiring and switch issues before ordering anything this adventurous....
skyline26
10-18-2013 10:31 AM
igotgas
02-28-2012 11:09 PM
Hiperguy
11-11-2010 02:09 PM
allman
10-12-2009 09:16 AM
imagepower
04-07-2009 08:06 AM
