Help
2008 hhr 2.2 manual...car dies overnight (new battery) flashers or blinkers never make a sound stock alarm works only after you turn of the ignition for a short time tire service light is always on an the tires read blank...
Tire Pressure Monitoring System where is the pcm located helpppppp!!!!
Same year and transmission
I'd have battery load tested first and foremost.
My TPS light is always on too. I have new sensors to install but can't get access to system with keyless remote (another story)
My HHR has more electrical gremlins than most any vehicle I've ever owned.
Battery test results?__________________________...
Might we assume this car is new to you?
Does it have the Original radio? The chimes are played by the radio.
Yes, 2008 models do need updated firmware for the RCDLR if the battery has gone dead. Replacing it will not fix it unless it gets the new firmware installed. To answer the question the RCDLR (the receiver for the fob and TPMS) is located under that bump in the headliner near the mirror.
Battery test results?________battery is new __________________...
