Help pending codes
Help pending codes
I have a 2010 Chevy hhr I had a p4022 code evap small leak detected. I purchased a new gas cap in the mean time my son disconnected the battery to clear the engine light being on. What is the drive mode for the ecm to notice the catalyst and evap pending when I hook up a code reader. Any input would be great fully appreciated.
The EVAP tests can take 15 cold start cycles to run. I assume you mean P0422? If you disconnected the battery the pending codes should have cleared; However there shouil be no need to clear the CEL that code clears itself soon after a repair. Always turn the gas cap until it clicks 3 times.
MercyCroft
10-18-2019 01:49 PM
