HHR AC Troubles
HHR AC Troubles
My AC is a little noisey and does not work well. I drive 17 miles to work and it's an still not cool in the car if it's above 80 outside. Also there is no Max AC any one else have the same frustrations.
Thanks in advance
Thanks in advance
Hmmm, well mine is a little "noisy" I suppose. But it cools dowm within a minute, so as far as that's concerned sounds like yours is ill. Max A/C really only directs all air to the face vents on cars, so since the HHR is a smaller vehicle perhaps they did away with it, but Max A/C never did anything to the air temp, i.e., it doesn't make the air colder. Take it in for warranty work is my advice.
I'm not a big fan of air conditioning, but the other day it actually hit 90. I fired up the a/c. No noise and WOW was it cold! My wife and said I was "lookin' a little bit perky", if you know what I mean. Absolutely no problems at all.
Location: Superior, WI - Over the Hill Warranty Club member
I have only got to use mine 2 times this year and what a great way to blow dry your hair with the fan on hi and the heater going while you drive to work...
Remember!!! Watch out for them Deer... Missed 4 this week.. 1 this morning..
pHHHewwwWW.. D'oHHH
pHHHewwwWW.. D'oHHH
I have nhad to use mine a few times over just this last month. Temps over 100 make you do that. So far I have had no problems. I will not know anything about the heater since that will probally never be used.
Heater Use
Isn't the first week in January proclaimed "You might actually have to use your heater week" in the Phoenix area?
