HHR design complaints
#81
Originally Posted by DJ Koz
What about the instrumental panel lights not coming on when putting on the parking lights or manually turning on the headlights? I tried turning off the auto lights and the instrument panel/radio lights don't come on during the day.
Anyone have an answer to that?
#82
Originally Posted by oldschoolfreak
all in all i like the hhr to much to ***** about little things I would have prefered the window switches on the door but no biggie. the only thing i wish was optional was a side opening rear door or a set that splits down the middle letting each pull out to the side as i am 6ft1 and have to duck down to get anything in or out But i still love it!!
#83
It has been raining here for a few days and I would like to see gutters on this thing. Anyone remeber cars with the little gutters above the window? With the large flat area of the roof, a lot of water collects. I stopped at a light today with the window down a bit. Lots O Water! I think the gutters might also push the nostalgic look. Whadya Think?
#84
I saw add-on chrome rain gutters in Pep Boys about a year ago. Don't know if they still carry them.
Bad part is....you need to drill and screw them into the inside area of the door shelf. The kit did provide a little tube of silicone to "seal" the hole.
#85
If you have keyless entry you must use the key fob,if you try to unlock the
doors with the key the horn and lights go off. The dealer said they all do this.....
#86
doors with the key the horn and lights go off. The dealer said the all do this.....
#87
Originally Posted by courthousedeb
Thanks x-ray1950...You are absolutely right. Just went out and opened with key instead of key fob and horn went off. Could have sworn it was the other door though. Guess my memory is worse than I thought, because I don't remember ever using the key in the door, except to try the new one when I got it from dealer.
#89
Speaking of keys, how many keys did everyone get with their HHR? I got 2 remotes and 1 key. Did my dealer forget to give me another key?
I think your dealer forgot to give you the second key. We received 2 keys and 2 remotes.
#90
