hhr headlight question
Old 09-21-2014 | 02:32 PM
jbowles49's Avatar
I had a fender bender with my 2008 . In replacing the fender the headlight appears separate from the plastic support bracket underneath. Are these two bonded from the factory? If so mine separated in the accident. Any info greatly appreciated.
Old 09-21-2014 | 02:43 PM
LawDog88's Avatar
I don't believe so. When I swapped out for DEPO's a while back the headlight came out separate from any other bracket or support piece.. Best of Luck to you!
Old 09-21-2014 | 02:52 PM
jbowles49's Avatar
headlight
So the headlight just sat on top of the bracket? Thanks
Old 09-21-2014 | 09:48 PM
Lucky's Avatar
This my be the part your looking for. Gm calls number 6 a headlight support bracket. You can get them on ebay
Old 09-21-2014 | 10:16 PM
jbowles49's Avatar
Many thanks
Old 09-21-2014 | 11:54 PM
It's properly known in "GM Speak" as a Support, Bumper/Fascia.
P/N 15836388 is for the Right side.
P/N 15836387 is for the Left side.
GM list is $14.15 each
Medic7419
08-31-2013 11:21 PM
Greylotus11
Mods - Exterior
01-17-2013 04:21 PM
bisho1p
41
11-11-2008 03:41 PM
mightymouse
0
07-06-2008 09:22 AM
