HHR key FOB
Old 03-09-2013, 06:31 AM
arciolla's Avatar
HHR key FOB
Can you re-program a Ford key FOB to a Chevy HHR? Also if not does anyone know the part number for a 2011 HHR key FOB. I see they have them on ebay but don't know the part number. Also does anyone have programming instructions for the FOB
Thanks Bob
arciolla is offline
Old 03-09-2013, 10:22 AM
No, Ford is Ford-GM is GM. Programming must be done with a TechII scan tool. 3 button 2011 p/n 15777636. Check the label on your glovebox door for code AP3, that is remote start. If it's not there, your only hope of remote start is aftermarket $$$.
Use the search tool on this forum for more info than you could possibly need.
donbrew is offline
Old 03-09-2013, 10:30 AM
Kevinmcl's Avatar
Different keyless entry systems are used on General Motors vehicles. The parts are not interchangeable even though the parts may appear to be similar. Observe the back of the transmitter in order to properly identify the system. On my 2009, GM/L: 15114374. Check ebay, many come with promgram instructions.
Hope this helps.
Kevin
Kevinmcl is offline
Radco's Avatar
I to have a 2011 . It does not have the AP3 code and as mentioned no remote start like the past model years. In 2011 GM set the FOB s up so they have to be done at the dealer .. My dealer charged me 65$ for a new Key FOB and programing. IMO not too bad a price.. You should call your local dealer to find a price of a key FOB and programing from them. Then get a price on programing yours. You may be surprised that the dealer purchase w/programing may be cheaper then you supplying your key FOB to have programed..... Just my 2 cents
Rich
Radco is offline
Old 03-09-2013, 02:22 PM
brown1243's Avatar
2 pads from keyless.com 18.95
brown1243 is offline
Old 03-09-2013, 03:07 PM
Hope this helps.
Kevin
For any HHR the programming instructions are "go to your local GM Service department". (period). You may find a locksmith with the correct tool. The BCM (computer) has to be programmed to the fob, not the other way around.
And to restate the obvious, use the search tool for at least 100 other threads covering this topic. This is one of the most over worked subjects, next to oil topics.
donbrew is offline
Old 03-09-2013, 03:15 PM
Radco's Avatar
Great deal Thanks . I can not find the FOBs ontheir site only house and key pads. Can you post the link? Thanks Rich
Radco is offline
Old 03-10-2013, 04:17 PM
brown1243's Avatar
they are replacement pads, just open the fob and replace.was real easy I'm 71 did it with no problem.
Old 04-08-2013, 03:57 PM
robinbraves's Avatar
Cool Broken Key Fob
Does anyone know if you can cancel the horn when you use your key to open the door instead of using the key fob? Ive looked through the DLC
settings but cant find it. Need to use the key until i receive a new FOB.
robinbraves is offline
Old 04-08-2013, 04:39 PM
Stick the key into the ignition and start the car.
donbrew is offline
