HHR will not warm up
Old 01-14-2023, 08:01 AM
Tool made for the purpose, available where automotive tools are sold:
donbrew is offline
Old 01-14-2023, 09:05 AM
I reach down from the top to loosen the drain plug.
Oldblue is online now
Old 01-14-2023, 09:52 AM
It's much more difficult on the SS.
I think FillerNeckSupply.com has a drain that goes inline with the lower hose. I'd link but their site is down for maintenance right now.
RJ_RS_SS_350 is offline
Old 01-14-2023, 10:25 AM
There are many sources for the drain , however I don’t like the idea of cutting a perfectly good hose and add 2 more clamps to possibly leak. Plus the lower rad hose isn’t at the bottom of the radiator tank
This version was from Jegs website
Old 01-14-2023, 02:23 PM
PulpFriction's Avatar
I bought a Mahle TX12282, along with a GM Genuine 131158. Looked identical. Tested them in a pan of heating water, and they opened in lockstep.
At Rock Auto the Mahle is $15.42 and the GM $66.79. Betcha Mahle made them both. Mahle is an OEM supplier of thermostats.
PulpFriction is offline
Old 01-14-2023, 02:25 PM
Interesting
Old 01-14-2023, 04:04 PM
Opening and closing is not the usual problem. It is the inner rubber gasket failing and jamming the valve open.
donbrew is offline
Old 01-14-2023, 04:31 PM
shojay92's Avatar
Yeah that appears to be what happened in my case. Drove it tonight so far so good👍
shojay92 is offline
Old 01-14-2023, 04:32 PM
shojay92's Avatar
I wish i knew that before I spent $66 dollars on an oem stat
shojay92 is offline
Old 01-15-2023, 07:39 AM
I’ve installed the Mahle thermostat and it failed after a month and a half
SSROADSTER
43
03-07-2022 08:46 PM
strongvoice1
09-19-2019 10:47 PM
Wirewoman
Maintenance and Upkeep
7
07-23-2017 03:43 PM
andoll83
12-07-2009 10:14 AM
REDHHRSS
06-03-2009 09:24 PM
Quick Reply: HHR will not warm up
