HID question
Old 10-15-2008 | 10:38 PM
halfpanel08's Avatar
HID question
I am on the verge of ordering HIDs.
I have a 2008 ls, are the bulbs for sure H13?
Also, is there any known problems with people using hids on the
hhr? Does the chevy wiring harness do fine with them? Does
the day time running option play out okay with them?
thanks for all input, i was bout to order them tonight
but decided to get input first before i place order.
Thanks,
HALFpanel (paul)
Old 10-15-2008 | 11:10 PM
Rcflyboy's Avatar
Yes I just replaced my 2008 bulbs with H13. Not Hid's though.
Old 10-15-2008 | 11:12 PM
okay well that answers one of my questions , thank you
now i need to know if there is any issues with people using hids..
Old 10-16-2008 | 01:50 AM
Deuces's Avatar
You'll probably get a lot of glare and people "flashing" you from the oncoming lanes. Best of luck, but a projector retrofit would be your best bet. They have the "upstops" to stop the glare for oncoming drivers
Old 10-16-2008 | 08:06 AM
haha, yeah ive already had HIDs on my past cars. people flash me
assuming my high beams are on, but they are just the HIDs. I always
get 5500k , those are about the brightest white you can get.
I just wanted to know if the chevy stock wire harness holds up good?
Old 10-16-2008 | 10:00 AM
mende's Avatar
The drl's normally run the headlights at a lower intensity. My sunfire runs the high beams, I'm not sure about our HHR's. If it runs the low beams, you would probably want to pull the drl fuse to make sure the HID's are getting full voltage.
Old 10-16-2008 | 03:42 PM
gcsd3742's Avatar
They work great...I have them in mine and you need the B i-Xenon kit I also have them in the Fog's as well....my pic is post #13
https://www.chevyhhr.net/forums/show...t=15714&page=2
Old 10-16-2008 | 10:39 PM
thanks man - i appreciate the help
betterof2evils4
04-03-2017 09:34 AM
FargoFlash
07-12-2011 05:54 PM
