High mileage club 100,000 plus
I just had to get the head reworked on my 2009 at 180,000 because of a misfire on cyl #1. Is this a common problem? When I picked mine up the service advisor said that they had another one in there for the same problem, but this guy did not get his repaired right then.
Mine wore out before 60,000 miles,so I put these on mine and they are great!!!!!!!!
Getting there. I have about 91k on mine right now.
Only problem I've had was that BCM the dealer replaced for me, and everything's in really nice shape otherwise. Since I'm real gentle on equipment, I'm hoping it stays that way for a long time.
Well i am around 176k with very few problems. Did the whole front end thing with sway bar links, hubs, struts around 150k, had a new throttle body installed around 140k, new catalytic converter around 95k (the flexy thing broke) and other than regular maintenance that has been about it. On my fourth set of tires and hoping to get many more miles out of it.
I have an 06 HHR LT with 145,400 miles on it. Other than the normal oil changes, rotate tires and on my 3rd set of tires - i haven't had any major issues with the car until now. I posted a few weeks back that my heater/AC motor just quit working.
I have not fixed it yet as i don't know what to look for on it Looking for help in this matter.
Thanx Everyone!
my signature line is way out of date as you can tell by this post . . .
Thanx Everyone!
The Minister of Sinister today 195,000 miles replaced so far;
4 pairs of headlights
2 pairs stock rotors then cross drilled rotors to finally solve the warping
2 O2 sensors
1 Catalytic converter
1 Map sensor
1 hub bearing assy
struts
shocks
shifter
and I just ordered everything to rebuild the front and rear suspension...everything !!!
2 O2 sensors
1 Map sensor
1 hub bearing assy
struts
shocks
shifter
