Hood latch assembly
Hood latch assembly
Got 2007 lt and my hood latch will not lock down the hood all the way tight and I try to adjust the hood bumpers and some times it works and when I pop the hood again and try to lock it down no go .. so my question is should get a another latch assembly it is a 2006 with the electric hook up .. are the years the same latch ?
I have to say it’s the latch assembly we’re it won’t lock down the hood and did spray it with silicone to make work better .. when pop the hood again then it won’t hold the hood down to a lock position.. I think the bumpers are fine but just won’t lock tight ..
Sticking cable maybe? Make sure the cable and latch mechanism are returning completely when you let go of the release lever.
I have Buick with a hood that needs a pretty good slam or it will pop up at some random time underway, hours or weeks later.
thanks old blue .. I’m going to spray latch down with oil and see if loosen up the catch lever from being rusted and adjust it better .. went to the boneyard and pick up a latch if I can’t get the one on car to work .. thanks guys for the help !
