Hood Switch Testing - Need help!
Old 06-05-2010 | 08:12 AM
  #31
tiresmokindad's Avatar
Re: Hood Switch Testing - Need help!
Originally Posted by donbrew
I have a ex-rental too, so can't help with the VOM. Does the existing harness even have the wires for the switch? Or is the AP3 harness an extension from a blank connector, that would be too easy?
I think I have the same problem. I think yes the existing harness have the wires for switch. I think it is not easy nor difficult, it is just an average.
Old 06-05-2010 | 09:56 AM
  #32
ChevyMgr's Avatar
This re-wire was solved.
https://www.chevyhhr.net/forums/how-tutorial-library-21/how-add-gm-remote-start-without-option-ap3-28551/
Old 06-05-2010 | 04:48 PM
  #33
jwl4261's Avatar
ChevyMgr.
Do you have the pin diagram for a 2007? Mine has four PU wires and none of them are in pin 3. Also the connector to the headlights under the hood is different from your diagram as well.
Thanks,
jwl4261
Silverfox
Maintenance and Upkeep
13
09-24-2012 02:58 AM
American & Proud
Mods - Exterior
60
06-26-2012 09:13 AM
ssdivin
South Central
03-22-2011 04:02 PM
