Horn questions...
I cannot find anything about a Fiamm horn either at the local Advane Auto Parts stores here in FL or on the web site. Is there a AAP part number for it?
nhisfan.....
If I understand your post correctly you had attached the new 'High Note" horn TO THE OEM HORN with a jumper, thus you have both horns emitting the sound. Did you change any fuses, relays.....or have you blown any fuses???? Do you know if the install is pulling more amps???
As for the Fiamm horn - that is the brand name. Unfortunately, today was trash day, so I don't have the package to give you any additional numbers. I did find the slip and it says "HORN UNIVERSAL HIGH TON 6200008"...
Hope that helps - geo
geo
Advance Auto site horn that is mentioned
http://www.partsamerica.com/ProductD...egoryCode=3074
I knew I should have snapped some pictures...
geo
alright I tried this today but could not get it to work, I took off the black cap where the factory plug goes on the horn and put an eyelet on there (for pos) put the cap on, grounded the new one hooked the pos (or so I thought) plugged the harness back in and just the factory horn worked, was pretty easy just messing up something, any thoughts? Thanks in advance, Guy
Hey Salty - if I remember correctly, the eyelet connection was a little loose, so I put a couple of star washers under the eyelet to take up some slack and tighten up the connection. It may just be as simple as a loose connection...
I also trimmed a little plastic from the connector so that the new wire would have a straighter angle and allow the connector to snap completely back in place (there were 3 retainers on the conn). Then I filled the gap with a little rtv when I was done to weatherproof it...
I knew I shoulda taken some pictures - geo
Just ordered one. That was about the only thing I hated on my new 08 HHR SS, The wimpy horn. Thanks
I bought mine online at Advance's site (PartsAmerica) on Friday to be p/u at my local store. Went in yesterday (Sat) and they don't have any record of it. Nothing on the shelf in back, nothing on the computer. I didn't have my receipt with me so will be going back in today taking it with me. I'm sure that will fix the issue but do any of you work there and know what the problem might be? Since I have the proof of purchase, I'm sure that it is really not a problem, but am curious as to why the problem occurred. Everything is correct on the order; my info and the store info.
