Horn Upgrade
Old 06-12-2010 | 10:00 AM
edstacoma's Avatar
ooga horn uses the same bracket good sound and a easy install
Old 06-12-2010 | 10:15 AM
Greybeard. You don't hear the horn when you set the alarm?
I don't have an alarm on the '07, and no the horn doesn't sound when I lock/unlock the doors with the remote for the keyless entry. Probably would if I pressed the "I can't find my car" button...... so far I've been able to find my car.
Old 06-12-2010 | 11:47 AM
oldpanman1's Avatar
I just put the El Grandes on and they're great. Since there is limited room to work in the fender well, after I took the old horn off, I assembled the two new horns outside of the car. I used a long bolt going through the mounting pieces that came with the horns and put a lock washer and nut on. Then lifted the whole assembly up into the fender well, slipped the long bolt through the original horn bracket, added a lock washer and a nut. I also found that by adding 12-18 inches of wire as suggested in one of the other posts, (after cutting off the old connector), I was able to easily put new connectors on also outside of the car. Once the horns were bolted up, it was a snap to attach the connectors to horns. Worked first time.
Old 06-12-2010 | 12:23 PM
Laco's Avatar
Isn't the alarm standard? It was on my 07, and mine is a very base, no frills HHR.
Old 06-12-2010 | 01:48 PM
Just theft deterrent, no alarm on mine
Old 06-12-2010 | 01:54 PM
hyperv6's Avatar
Never heard my HHR's horn. I very rarely use a car's horn and think people tend to over use them. (personal opinion) Never heard the horn in my Astro either and I owned that for 5+ years....
Adding a second would work but make sure you check that you aren't exceeding the amperage of the stock fuse/wiring......... Nothing very "cool" about having that great big horn if it pops the fuse when you use it.
Most nomal duel horns go right in but if you want the big blast horns they often have a upgraded relay to make them work fine.
Old 06-12-2010 | 07:16 PM
papajim's Avatar
Horn upgrade
Thanks for the info guys! I believe I can handle it.
Papajim
Old 06-12-2010 | 07:34 PM
Laco's Avatar
Hmmm, surprises me, as mine was a bare bones, zero option, 2.2 five speed, but has a full alarm, which sure didn't show as an option. In fact there were zero options listed on that car. Price was very attractive for a brand new car.
Old 06-12-2010 | 07:41 PM
oneton's Avatar
It has one he just don't use it!
Old 06-14-2010 | 05:14 PM
mrsilent13's Avatar
my SS alarm is disabled or something...not only that i dont even have a key fob...i bought it 2 weeks ago...but im going back to the dealer tomorrow and getting this fixed
