How to clean evaporator of air conditioner
Old 12-12-2013 | 11:39 AM
There are aerosol products on the market for the purpose. I think BG also GM sells one. Basically you spray into the cavity under the cabin air filter and the foam expands and sits for a while then drains out, hopefully you cleaned the drain first.
Blue_SS's Avatar
One other easy tip to help keep it from getting/staying funky is to make sure you are pulling outside air and not re-circulating under most conditions. Re-circ does work better in high heat, but switch it back or you'll be smelling musty stuff. Fresh air really helps.
Old 12-12-2013 | 11:47 AM
It switches back EVERY time you re start the car. GM does not want you to use recirc as a normal operation. If you push the recirc button the A/C will come on, but the A/C light does not. When you shut the motor down it goes back to fresh by default.
Old 12-13-2013 | 01:58 AM
Originally Posted by Silverfox
Not sure if what I have always done is the best preventative but I have never had a fowl oder from the AC in any car I have owned. That's a lot of car/trucks.
I admit in this climate, AC is only used off and on for approx. 4 months of the summer and once in a while in the winter to reduce interior moisturer.
Each time I use AC, I finish up the day with the AC off and air dry the humidity and moisture out of the system.
Works for me and it only takes a minute with the fan on high.
SF
SF- That's precisely what I do & no fowl odors in my rides either.
& always use Fresh air mode as well.. .
Old 12-13-2013 | 02:30 AM
prod's Avatar
It also helps to crank the AC with full heat on to dry it out, helps prevent mildew. Ive corrected the odor after a few days of that, no spray products.
Old 12-14-2013 | 03:06 PM
I finally noticed that this thread was in the "how to" forum. I moved it.
logcar
Maintenance and Upkeep
06-21-2024 09:12 PM
reno2011
07-24-2014 06:23 AM
noleal
08-23-2012 06:36 AM
Lone Ranger
06-29-2007 09:12 PM
Quick Reply: How to clean evaporator of air conditioner
