How to tell what model my HHR is.
Old 03-11-2015, 12:28 PM
snyper1982's Avatar
How can I tell if my hhr is a ls, or lt, or any other models they might have. Thanks.
snyper1982 is offline
Old 03-11-2015, 02:07 PM
Lucky's Avatar
Welcome to the site
The most accurate way is to look at the decal is the glove box. It should list LS,1LT or 2LT. Trim package.
Lucky is offline
Old 03-11-2015, 02:09 PM
Welcome to the site.
Since you didn't give any details of how your's is equipped, (don't take this the wrong way), but, what does it say on the rear hatch door ?
LS---basic with 2.2
LT---either 1LT or 2LT depending on options
SS---Performance model
firemangeorge is offline
Old 03-11-2015, 02:14 PM
Welcome to the site, have a look at the options sticker on the glove box door.
Oldblue is offline
Old 03-11-2015, 08:40 PM
ThatChevy's Avatar
Welcome to the forum. As others have mentioned you can check the sticker in the glove box or the rear hatch to see if you have an LS, LT, or SS. Another way you can check is based on engine size or vehicle options.
For example:
LS- 2.2L is the only engine available.
1LT- 2.2L is standard, but 2.4L is optional.
2LT- 2.4L is standard.
SS- came with the 2.0L turbocharged engine.
If you're wondering how to check and see which engine you have, look for the emissions sticker under the hood and it will tell you the engine your HHR came equipped with.
ThatChevy is offline
Old 03-12-2015, 08:15 AM
Ron S's Avatar
Welcome to the site
Ron S is offline
Old 03-12-2015, 07:13 PM
Cols2009HHR's Avatar
check-lookup VIN decoder - Check check-lookup VIN number and get full factory options list for free. Check check-lookup history, price and car loans.
Found this place on the internet. You put your VIN number in and it tells you all the options that were installed on your car. Just thought I'd share.
Cols2009HHR is offline
Old 01-18-2018, 10:13 AM
Patrick Michaels's Avatar
I tried the vin decoder, but i can't tell much. It says i have a 2.2 engine, but a manual transmission which i don't. The glove box sticker is cryptic.
It does have a 1lt in the last line, but doesn't mention engine size. Does that mean 2.2?
Patrick Michaels is offline
Old 01-18-2018, 10:24 AM
Cryptic ? No.
Just do a little Search and you could deceipher the RPO codes with the link below.
https://www.chevyhhr.net/forums/gene...options-12674/
Old 01-18-2018, 11:02 AM
You have a LE8, or 2.2 with VVT and flex fuel. And the MN5 automatic 4spd transmission
Oldblue is offline
Quick Reply: How to tell what model my HHR is.
