How To Use Recovery Strap ?
I searched but could not find info. But I'm old and can not always find thing s :O
With the heavy snow and Ice up north, we get a lot sliding off the road is not uncommon! I had a 4x4 Tracker and it had tow/recovery hooks front and rear. The HHR from looking at the bottom , to try and hook up doesn't look good! Only good hook up looks to be rear frame and or axle, the angle does'nt look great as the strap will may hit rear bumper!
Any info on how to pull the HHR out of a ditch/best hook up points and not beat up the HHR's?
Thanks
Thanks
came across this on the web:
http://www.ehow.com/how_8551089_tow-...out-ditch.html
i suppose, if a guy wanted to, he could bolt on a couple heavy duty eyelets to the front frame area for future use?
Anything in the OM on the topic?
I never noticed the absence before, I guess the fact that they are land transported from the factory rather than sea is the reason. I asked somebody one time why the prominent hook hole on Imported cars the answer was for shipping tie-down for transport by sea.
As I'm in the towing recovery business, the best way for me to do it is using a proper recovery strap, and depending on how it's sitting, either basket a wheel (and if it's done right it WILL NOT damage any component) or if I can do a straight pull, put the strap thru the rear doors, then under the body and out the front, once again, if done properly it wont hurt anything and wont bend/kink the bumper. I've done many HHR's like this and every single one has driven away once its out.
I found out when a rookie recovery driver loaded my 2008 up that you should not use the holes in the rear of the frame. He used one to lock the car down and can-openered a nice chunk of metal. Didn't seem to affect anything structurally, but still.
Think Ill grad a 20 ft, recovery strap and a 15/20 ft strap with hooks
