Hub removal tool
Old 03-09-2020, 06:37 AM
Cat Man HHR's Avatar
Hub removal tool
I know the tool is made to remove a stuck on front hub on our cars
But what if you buy a steel Harbor Freight large pipe wrench and use its jaws to clamp onto the hub flange , put a long strong thick wall pipe (black pipe or fence pipe ) on the handel and hit that with a 5 lb. hammer ?
Maybe even rectangular tubing ?
Just a thought thrown out here.
Cat Man HHR is offline
Old 03-09-2020, 05:28 PM
Blue_SS's Avatar
I have always been able to use a gear puller, a PB blaster soak, and a 3 lb. mini sledge "persuader". Soak it, put it under tension with the puller, and pop it as needed with the bfh. It might take some time, but it works.
Blue_SS is offline
Old 04-03-2020, 08:10 AM
The rear hubs on HHR just fall off, no need for the tool. It's the fronts that offer resistance.
donbrew is offline
Old 04-03-2020, 10:45 AM
WoodysMobile's Avatar
Air chisel with a blunt tip helps loosen things up after the soak with penetrating oil.
then refer to donbrew's 3 rules. If that doesn't work...
... get a bigger hammer and another brew!
wear safety googles face mask optional
WoodysMobile is offline
Old 04-07-2020, 12:23 PM
geg
geg's Avatar
changed the hub a couple of weeks ago ...
nail puller turned out to be useful
however, the hub was not overly jammed
geg is offline
Old 04-07-2020, 12:35 PM
Do you have a picture on the nail puller ?
Old 04-07-2020, 09:02 PM
My vintage axle puller works great on hubs. It has a slide hammer on it. No fuss, no muss.
sleeper is offline
Old 04-07-2020, 10:15 PM
OshawaHHRss's Avatar
I’ve had the axle seized to the hub and hub seized to the knuckle before. Had to replace everything lol
OshawaHHRss is offline
Old 04-08-2020, 03:47 AM
You just shook some dust off my brain.
I had one or still do somewhere.
Got to look for it. Lol.
Old 04-08-2020, 08:33 PM
Hope you find it Cat Man. That is the ticket imo.
sleeper is offline
Quick Reply: Hub removal tool
