Hydraulic floor jacks - 2 ton sufficient?
Sandybeach - you're right, balancing is very important. However, with proper rotation tire wear should be fairly consistent so the wheel balance shouldn't be thrown off.
It doesn't hurt to have it checked though! (especially is you have cheap access to a wheel balancer!).
Check out Clue 4 of my Find the HHR Contest..... Now Posted
I change oil and filter, rotate tires (with the related maintenance. stated) and take it into a tire shop for balance. I pay one time for life time balance and indicate, at the time of payment, that I will be back frequently for the rebalance. Haven't had a problem yet.
Thanks for the info fastsuv and Snoopy.
Debating whether to get the 2 ton or 3 1/2 ton jack stands.
