I am a Dumb a$$ by a triple play move
D A Move # 1-Got into HHR to move out of driveway to put Impala in. Put key in ignition-doesn't turn-thought o'crap ignition broken-but no-finally realize Impala key in HHR.
D A Move # 2-Get keys from other pocket while still in HHR. Put key in ignition-doesn't turn-thought o'crap ignition broken-but no-after fiddling with the steering wheel & then the key release button-finally realize Cobalt key in HHR.
D A Move # 3-Couldn't find HHR keys & Had to go to store, changed shorts, grabbed extra set of HHR keys & put them on the table-phone rings-get off phone, got outside into HHR, put hand in pocket of shorts just put on-pull out HHR keys-use them-and then realize they were the original keys I was looking for and left the spare set on the table. DOH!
Thus making the triple play of stupidity.
You have a way to go to catch me. About ten years ago now while living in snow country I slid into the driveway and rear ended one of my own cars. Now to make things even worse, the rear ended car then slid into and through the garage door. Nothing like trying to explain two crunched cars and one totaled garage door, all self inflicted, to the insurance adjuster. I can laugh about it now, but back then I wanted to crawl in a hole!
843de-You had witnesses I am sure, let alone the insurance adjuster. My little episode pales to yours, my wife doesn't know what I did to call me a dumb a$$, and no one knows but you guys!
Thanks to all of you I feel BRILLIANT!
Mostly in recent vehicles. But noticed it as correct on MOST older ones that have a fuel pump image with a hose. The hose indicates which side. Also if you remember which side the exhaust exits, the fill is GENERALLY on the opposite.
I understand your confusion. I have the same problem with owned, rented and leased vehicles. So I always try for a GM and the arrow.
If you can remember to take your short term memory pills in the morning, all would be just fine. The problem I have is that I can't remember where I put them and then #$%$#@#$*&(+ breaks loose.
See ya down the road
Bud-Harvey ( I think thats who I am, forgot again)
