I need to vent!!!
Old 03-06-2008 | 10:51 PM
jeffs396's Avatar
I've had issues with wheel weights before also. Alot of the time it's the punk kid making minimum wage that doesn't really give a rat's a$$. Other times they reuse weights, and they just don't hold anymore. I've also experienced some alloy wheels have a thick bead flange that will only accept certain weights. Have had the best luck with stick on weights like Craig mentions, but I always wipe the inner rim with lacquer thinner before I go so they adhere properly, then once I get home with the assemblies I use a fine sharpie to trace around the weight cluster(in case they launch, you can replace easily without going to the tire shop), lastly I use a tiny bead of gray RTV around the perimeter of the weights...I've yet to lose one after doing this. I don't have alloy wheels balanced with weights on the visible side anymore, they just don't look good! Steel wheels are OK because they either have a hubcap or trim ring covering them!
Old 03-07-2008 | 12:50 AM
Snoopy's Avatar
Really great info, IMO, jeffs396.
I do exactly the same, sans the RTV.
FURIOUS10
12-12-2011 11:47 PM
GRUMPEE
04-08-2008 02:41 PM
HipHotRod
South Pacific
10
01-29-2008 07:54 AM
Lee3333
11-09-2006 08:24 AM
baby143forever
05-10-2006 04:05 AM
