Installation under hood light
Old 12-01-2021 | 12:42 PM
tomasorta's Avatar
Hi I have a project in hand and is to install a bulb under the hood to check the engine in case need it at night, so somebody can give any idea what kind of the bulb I can I use for that? I need a switch to turn on and off when close the hood will be off the light and when open the hood has to turn on the light or can be manual to let me do that by myself.
Old 12-01-2021 | 12:59 PM
Radco's Avatar
You can buy a under hood light kit. My Truck did not come with one but did have the wiring harness for it ! About 20$
You would need a hot and ground and a fused hot leg !
Funny thing is I was just thinking about doing that on my HHR as I have a extra light kit!
SO hopefully the gear heads pop in with better advice, But i was thinking of a Fused Hot leg from the battery and ground to frame ! Not sure if there is a better way ! FYI I would also go with a LED Bulb WAY better lighting!
Found these on
Amazon and
You Tube https://video.search.yahoo.com/search/video?fr=yfp-t&ei=UTF-8&p=you+tube++under+hood+light#id=1&vid=69b52d8f54 1c56ed101dab8d1d5aa116&action=click
and
https://www.amazon.com/under-hood-light-Automotive/s?k=under+hood+light&rh=n%3A15684181 https://www.amazon.com/under-hood-light-Automotive/s?k=under+hood+light&rh=n%3A15684181
Old 12-01-2021 | 01:31 PM
tomasorta's Avatar
I saw other video using leds strips, installing almost close to the radiator underhood with 3m strips, so but the video guy don't show where buy that kind of led strips, in our case with HHR I don't know if connecting to the wire positive in the positive in the front car and the negative connected to the chassis will work I don't know, because the battery for HHR is in the back, but the led strips will work better with better illumination.so if you know where buy the led strips let me know, ok? thanks
Old 12-01-2021 | 03:10 PM
I found several kits with led strips, wires and a switch in most kits
https://can.grandado.com/products/wh...nQ6ODgxMjIxMjg
I don’t know if you can open this link
Old 12-01-2021 | 04:28 PM
Ebay, Amazon, Any of the Chinese ebay clones. Pretty darn easy with a internet connection.
tsbrewers's Avatar
My favorite one was one on my 1991 silverado. It had a retractable cord and could use it like a flashlight.
My current underhood light is a flashlight I keep in the glove box of every vehicle.
Old 12-01-2021 | 04:33 PM
Here’s the part number for the 91 Silverado light
15528774 you might find one online
Old 12-01-2021 | 04:38 PM
tsbrewers's Avatar
Thanks, quite a few floating around, mostly ebay. Here is a story of updating one to LEDs,
https://www.motortrend.com/how-to/16...od-reel-light/
Old 12-01-2021 | 05:50 PM
tomasorta's Avatar
thanks oldblue
Old 12-01-2021 | 05:52 PM
tomasorta's Avatar
in the case of the HHR the battery is in the back, so can I connect to the cable positive in the positive front and the negative cable to the chassis?
