Installed a scanner...
Old 07-06-2010 | 06:33 PM
pstar's Avatar
I installed a scanner in my '09 1LT. I connected the power lead to the audio fuse in the cabin fuse box but discovered that port is always live (not controlled by the ingnition switch). Can anyone recommend a fuse port I can use in the cabin box that goes dead when the key is removed? I don't want to run the battery down if I forget to turn the scanner off and I'd prefer not to have to run the power lead out thru the fire wall to the engine bay fuse box.
Old 07-06-2010 | 08:43 PM
Laco's Avatar
Try fuse 8, on the right side of the console. It controls the odometer, radio and the SRS system.
Old 07-06-2010 | 09:25 PM
skyeglen's Avatar
If you want it on its own fuse try #21 that is controled by the key or #28 that is a constant hot. Both are unused by any other devices.
Sorry, didn't see you have a '09. The above works for a '06. Don't know about other years.
jay loukakis
01-15-2014 08:33 AM
chevyorange
North Pacific
02-24-2012 01:10 AM
cajunken
03-29-2011 06:50 AM
rotaryboy23
02-22-2010 09:56 PM
442dude
2.2L Performance Tech
01-10-2008 08:30 AM
