Installing used factory seat belts and back seat in 2010 panel
Old 12-03-2017, 10:39 AM
Ohirolina's Avatar
Purchased a used rear seat and the factory seat belts out of a wrecked HHR. I did a search and was unable to find a fix so I have to ask. When I went to mount the seat belts they were fully retracted inside the spring loaded housing. For some reason I can not get them to extend back out so I can bolt the head and bottom points. Any suggestions? They came out of a 2008 LT and are going in 2010 LS.
Thanks
Ohirolina is offline
Old 12-03-2017, 11:30 AM
RF2
RF2's Avatar
Were the seat belts triggered from the car being wrecked? You may have to send them in to be rebuilt and reset. Try Safetyrestore.com
RF2 is offline
Old 12-03-2017, 12:29 PM
Ohirolina's Avatar
No. They were still installed in the vehicle when I removed them. The vehicle sustained front end damage. No one was using the seat belts in the rear.
Old 12-03-2017, 01:44 PM
Cat Man HHR's Avatar
Found this, it's for another vehicle but maybe the GM has the same type of check ball once you take the cover off.
Do you still have the old one to practice on?
Cat Man HHR is offline
Old 12-03-2017, 01:57 PM
Here's another one for a 2005 GM. Even though it's not that great of a video the guy shows the locking "cylinder".
Old 12-03-2017, 03:02 PM
This is about all that I can find, I think there is a gravity activated ratchet.
donbrew is offline
Old 12-03-2017, 06:47 PM
Ohirolina's Avatar
After watching these videos I decided to try Don Brew's schematic first, BINGO. I was just going about it wrong. While holding it plumb/level it easily pulls out.
Thank You all for trying to help.
For my next trick, I am going to install adhesive backed sound deadening material on the inside of the panels, floor, and inside of all four doors plus replace all four door speakers.
Thanks again for the help!
Old 12-03-2017, 07:09 PM
So, what about the exhaust leak ? Shouldn't that come 1st ?
(the other thread you started and didn't come back to )
firemangeorge is offline
Old 12-03-2017, 08:16 PM
Ohirolina's Avatar
Hmmm, You are probably right. I should have done that first. I am going to order the replacement piece right now.
Old 12-04-2017, 06:25 PM
Ohirolina's Avatar
Due date 12/11. Ordered a full length down pipe. Has a weave type flex pipe and two converters. Does it take a special socket to remove the O2 sensors? I read somewhere where the guy had a socket just for that.
Quick Reply: Installing used factory seat belts and back seat in 2010 panel
