Interior quality rant
Old 07-09-2012, 08:07 PM
Devils950003's Avatar
Originally Posted by Snoopy
your rant is interesting and SOMEWHAT relevant BUT,
you apparently weren't around for the vehicles of the 50's, 60', 70's and maybe the 80's. Those interiors, even though made of more substantial material, were close to trash at that time. This was a major complaint by the consumer....according to manufacturer surveys. Glove box wouldn't close, doors fit like they were "dropped" together, dash materials split, upholstery faded and and ripped easily (unless it was leather), carpet didn't fit under the floor trim....trim alignment between 2 pieces was off by 1/4 inch, windows leaked water.
In short, the consumer was testing the vehicle for the manufacturer.
While, yes, the materials are plastic and thus fuel efficient lighter, the design, fit and finish is far superior.
The real question.....eliminating ALL other efficiencies, would you pay maybe $1500-2000 for an upgraded interior to metal products, heavier carpeting and better upholstery with maybe 3-4 MPG less?
Remember, while the HHR is an interesting design, it is essentially an economy car.....even in the SS version.
Great points...as someone who was born in 1970, I can tell you that 1970s and 80s interiors were TERRIBLE as far as quality goes...collapsing cloth ceilings (remember those), interior door handles that came off in your hand as you pulled the doors shut, dashes that dried out and cracked and split...I can go on and on, though you covered many of the common flaws already. Those interiors were flat-out not built to last and it showed.
Devils950003 is offline
Old 07-09-2012, 08:15 PM
badassbowtie's Avatar
I do agree with you.... I really only meant cars were heavier in general back then. even if the interiors were junk, i would bet they were made of heavier material.
The main point i was making was that to gain maybe 5mpgs, the interiors are skipped out on. and while they feel cheap, they are still a relatively sleek design for being plastic. I'm 99% fine with my interior. with the exception of the spot where i rest my arm, which im used to
badassbowtie is offline
Old 07-09-2012, 08:18 PM
swerv0428's Avatar
You can always make it your own. You can change whatever you want for some $$$$$.
Well I was born in 1990. So the 80's are a grey area for me. but I do recall my dads camaro have a cracked dashboard.
swerv0428 is offline
Old 07-09-2012, 08:26 PM
The cracked dash thing was very common back in the day. What made that even worse was that the dashes were usually made of foam underneath the surface, so where the interiors cracked you'd see this exposed foam rapidly discoloring.
Old 07-09-2012, 08:43 PM
swerv0428's Avatar
I believe it was a 84 z28. I was young when he had it maybe 10 or so when it was sold but I do recall that there was a yellow foam looking under the dash. You could see it threw the cracks.
Old 07-09-2012, 09:06 PM
Krash Kadillak's Avatar
I respectfully disagree with the OP's opinion.
While I have a 2LT with the leather seats, I have driven a 'plain' 1 LT with the cloth seats (which I believe are the same as the LS seats). I found those seats to be be perfectly acceptable. Everything fits together well. I saw no evidence of shoddy workmanship. It was actually a very big improvement over my last Chevy, which was a '96 Blazer. The only issue that I've had in the interior is a loose dash 12v outlet. I find the area behind the front seats to be extremely versatile. I've had to haul a Little Giant ladder around, and all I have to do is flip the right half of the back seat down and it swallows it right up. I've been able to put an amazing amount of stuff in the back.
Krash Kadillak is offline
Old 07-09-2012, 09:24 PM
swerv0428's Avatar
Agree with you. I have an ls with the cloth seats. Everything flows together. J happen to like the grey interior. My only interior gripes are the door locks which stick up when locked, arm killer with window down. And the fragile interior door handles. Other than that I live it.
Old 07-09-2012, 09:31 PM
I am not compaining about the interior at all.....Im complaining about people complaing how cars are built like crap especially the interiors. I said i was fine with mine and it looked pretty sleek. I agree also that its nice for being an "economy" car....I never once complained about the interior and i respect the fact the chevy put suede inserts in the seats.... It could be worse. the engines in these cars are meant to last the life of the car, if not longer. and the "100,000 miles plus" members will probably tell you that if anything, the engine still runs like new. the ecotec is one of the best and most versatile engines around
Old 07-09-2012, 09:43 PM
swerv0428's Avatar
Amen. I'd much rather have a junk interior but a good reliable car then a great interior to sit in a repair shop all the time.
Old 07-09-2012, 11:31 PM
ChevyM84's Avatar
what i hate is people comparing the quality with cars like the Lexus RX which is double the price.........
ChevyM84 is offline
Quick Reply: Interior quality rant
