Intermittent headlight issues
Old 04-02-2019 | 09:10 PM
  #41
092lt's Avatar
When I replaced them the book said h-13's but I'm thinking I'm going to pull and replace them with a different brand. It sucks because they are only 2-3 months old but why not swap them out to rule that issue out
Old 04-02-2019 | 09:18 PM
  #42
092lt's Avatar
I hope I am not being a pain but this is driving me nuts. I feel like I'm running circles rechecking everything
Old 04-03-2019 | 09:59 AM
  #43
Go to your point of purchase , they may refund you your money
Old 04-17-2019 | 04:50 AM
  #44
092lt's Avatar
I give up. I have changed the bulbs again, went through the wiring, grounds and sockets again, checked the fuses and relays again and got the same results. If I can pass inspection I'll be ok and worry about it later. Thanks for all the help
Old 04-17-2019 | 07:53 AM
  #45
Have you changed out the multi switch on the steering column?
Old 04-17-2019 | 09:09 AM
  #46
Did you make sure all 3 relays and all the fuses are securely plugged in and the fuse box is screws are tight?
Old 04-17-2019 | 11:34 AM
  #47
092lt's Avatar
Multiple times
Old 04-17-2019 | 11:37 AM
  #48
092lt's Avatar
I did with an ac Delco part. The lights still acted up but the only difference is with the new switch the turn signal mechanism would click but fail to shut off after making a turn in about a week so I returned it and put the old one back in
Old 04-17-2019 | 11:40 AM
  #49
092lt's Avatar
I'm just throwing the towel in. I'm going to take it in for an inspection and pray the lights don't misbehave. After that it is what it is
Old 04-17-2019 | 12:34 PM
  #50
Since everything is eliminated it must be the internal part of the fuse box. That is the ONLY common point to the 5 systems.
Quick Reply: Intermittent headlight issues
