Joy turns to Frustration!
I finally get my Beast back from the shop after ditz rear ends me. They did a good job, but not too pleased by the two small scratches they caused...even more unhappy that the manager whips out touch up paint.
Ok, I can deal with that later.
I get home and paint my ashtray and front console cover. No real problems, got it put back together this morning.
Then I decide to take a drive -- turn the key and only clicking! I checked all of the electrical systems that are on the console and verified that they work. So it isnt battery (I had initially tried to charge it, but it took no ampers)...my guess is the starter...any other thoughts or helps out there?
Originally Posted by AMHobby
Try your other key. One of mine lost is't programming and had to be reprogrammed during delivery.
Tow truck comes in a hour.
What is the bat. volts? having lights , radio , windows working don't say that the bat. is at 12v CK bat cables for being loose did you not say it was hit in rear ? Takes alot more to turn starter over then light the lights or play the radio. its called amps
I would definitely check the battery cables and make sure they are snug, as I'm sure they were disconnected while it was at the shop. Hopefully it's that simple...if not, that definitely stinks. Please keep us posted.
Thanks for the suggestions all.
Zagohhr
10-22-2010 07:54 AM
