Just ordered rear sway bar!
Really great customer service from Never Enough Auto!!!
http://www.neverenoughauto.com/index...roduct_id=2199
I have one as well. The HHR is my first front drive car and I HAD to make it more nuetral handling. The Progress bar did the trick. I drive turns hard when I can. It's fun and the bar made a noticeable difference. Takes a lot less steering input to turn. The car is very stable. I'm really liking this.
May try an autocross event this summer just to see how it does.
The install was a snap. It took me longer to get and set the ramps then bolt up the bar.
Got mine from Aaron at Turbo Tech Racing, got it 2 days after ordering. AWSOME seller and a supporting vendor to this website
Aaron=
GREAT purchase as well, made the car handle a LOT better, it is the only suspension mod I have done so far and I am pleased at the increase in cornering and overall handling. I installed one on my Previous car, a cavalier, and was amazed at how much understeer was decreased from the stock suspension, and really balanced the suspension more.
Aaron=
http://progressauto.com/store/produc...roducts_id=397 was where I got mine. Easy to install and it helps keeps the back from swaying so much on turns. I did not care for the lean when going around corners so tha anti-sway bar was an easy fix.
I drove my 2Lt with the stock sport susupension plus an aftermarket sway bar for a while, and was amazed by how neutral and predictable in hard cornering this set up was. The car still sat too high and leaned too much in the turns for my taste, so I installed a set of Eibach Pro Kit springs. I'm a sports car guy from way back, and I've got to say that I'm very satisfied with this combination of springs and sway bar! The car is a ball to drive now, and looks better, too!
