Just a thought
Just a thought
To make the cabin cool down faster using the AC I thought about using a see thru curtain that could be hung on the coat hooks behind the rear seats. Only problem is where to buy a material that you wouldn't have a problem seeing thru clearly.
Maybe use 1/8" clear sheet plastic cut to size and use hooks or rings to attach to coat hooks ?
Ideas on this one ?
Ideas on this one ?
Acrylic sheets are far less $$ than Plexi-glas and difficult to see through but if you're really mechanically inclined - how about installing a window in between the back seat and cargo area that rolls up-and-down like some of the newer Toyota trucks. I know it's a stretch... LOL
