Key FOB SOB
Old 05-21-2008 | 08:43 PM
Lone Ranger's Avatar
Key FOB SOB
Key FOB failed to function as of after work today. Nothing. Nada. Zilch. Had to key my way in old school style. Got home and tried the spare FOB, worked fine. Tried the primary one again, nothing. Nada. Zilch. Almost a year to the day I took delivery (see sig).
Old 05-21-2008 | 08:58 PM
itschaboykenny's Avatar
i know there is a thread somewhere around here about the wires coming loose. use search function you might be able to find it or someone will chime in....
Old 05-21-2008 | 09:01 PM
karen1953's Avatar
Possible just a battery,,One of mine worked then did not.
Dealer found it faulty, and they replaced it.
Just remember to take both to the dealer so they can both be programed together.
Good Luck!
Old 05-21-2008 | 09:02 PM
tim_tenn's Avatar
Dumb question, but you have checked the battery, right? I had a key fob stop working and found it was a dead battery. Changed it and all was fine. Less than 3 months later, it died again. Battery was dead. Long story short, 2 more batteries later and I found that when I put my keys in my brief case after arriving at work, there was pressure put on the buttons so it was in a near-constant state of transmission. Ran the batteries down quickly.
Old 05-21-2008 | 09:39 PM
donbb82's Avatar
Mine did that so I took it to the dealer and they had to solder the wires now it works great!
Old 05-21-2008 | 09:49 PM
ChevyMgr's Avatar
Lone Ranger, hi ho buddy, surely you are under 36K, take it to the dealer and have it replaced. Take the other one with you, they must program both at the same time.
Old 05-22-2008 | 07:30 AM
My faulty (whether battery or wire) FOB was taken care of this way.
Old 05-22-2008 | 08:58 AM
Yes, about to click over to 9000 miles on the clock by the weekend. 9000 miles in a year... guess need to drive more... no wait, gas went to $3.99/gal here lastnight so I think I need to drive even less, lol.
Old 05-22-2008 | 10:40 AM
ChevyMgr's Avatar
Kathie, was that done under warranty?
Old 05-22-2008 | 11:44 AM
donbb82's Avatar
Yes it was done under warranty.
