kill switch
kill switch
I have a 2010 HHR and the key is stuck in the ignition lock cylinder in the on mode. So has anyone ever wired in a kill switch of some kind without cutting into the factory wire harness back by the battery before?
Yes I know about the recall and its just been about a month and kinda getting tired of walking around my HHR and not being able to enjoy driving it. The dealer said it might be another month and a half yet... So thats why I was going to wire in a kill switch.
I used one of these and a short battery cable between it and the ground screw in the battery bay.
Battery Disconnect Master Kill Switch Cut Off Marine RV with Quick Removable Key | eBay
The key stuck in the iginition switch is different from the recall. There was a bullitin on that. It happened to mine not too long after I got it and they replaced just the lock cylinder. Do a search on it. There is a way to release the switch from under the key assembly on the steering column.
Yeah there is a small square cover under the ignition, stick something in there and push the release while turning the key. In my case that didn't work so I just pulled the fuel pump relay in the underhood fuse box.
