LCA bushings
Old 07-06-2020 | 03:35 PM
Another instance where the books are wrong. The GM part number referenced is https://www.wholesalegmpartsonline.c.../88876501.html
Fits all HHRs, goes all the way back to the 1995 Cavalier. We all get the same bushing from the factory.
Old 07-06-2020 | 04:35 PM
Ok, then how come the bushings in Oldblue, the BlackSwan are the hinged type and the bushings in several SS’s I’ve replaced for friends are the solid rubber ? I’ve done a few Cobalt SS’s and those are solid rubber also.
It doesn’t matter much now because all the bushings I see listed now for the LS/LT FE1 or 3 or the SS FE5 are all solid now , must be something about they last longer, or are cheaper to manufacture.
Point is , I wouldn’t hang a pair of LCA’s in the wall in the shop again waiting as a replacement, just order a set of Moog or AC Delco arms and be done with it . These ones here I’ve had for 5 or 6 years now.
On the other hand , if I owned an SS with the FE5 suspension, I would order a set of those now, they are out of production 10 years now and are specifically SS because of the ball Joints
Old 07-07-2020 | 07:57 PM
prod's Avatar
And just because it is listed as a replacement part, does not necessarily mean it is the same as the original.
Old 08-22-2021 | 12:53 PM
The FE5 AC Delco bushings I installed on July 28, 2020 failed in August 2021. The solid rubber bushing cracked loose and pulled clean out of the metal ring . I’ve switched back to the Moog K201285 , they are much better, easier to press into the arm .
Old 08-23-2021 | 11:35 AM
tiapetra's Avatar
Not a good part number???
Old 08-23-2021 | 12:30 PM
Sorry, fat finger fumble! It’s K201285 enter the part number into the RockAuto website.
https://www.rockauto.com/en/parts/mo...m+bushing,7532
https://www.moog-suspension-parts.com/moog-k201285
Old 08-23-2021 | 04:44 PM
tiapetra's Avatar
Thanks for the number. When I tried Moog k201235 nothing came up.
Reason I was interested is because I put the K201285 joint in back in February and was curious as to what your upgrade was.
I have to remove my LCAs soon and will be able to check those bushings for wear. Hope they don't fail as your original upgrades did.
Old 08-23-2021 | 05:10 PM
Moog warranty is life time! At least up here in Canada
Old 10-25-2021 | 03:33 AM
Truckingeek's Avatar
Did you press them out/in Old Blue or have it done for you?
Old 10-25-2021 | 07:21 AM
I press them in. I have a tool for that.
